Phone not esim compatible
MattGrill
I paid for subscription just to find out my phone is not esim compatible. Can I get a refund?
iPhone XR supports eSIM and will work with PM
 Message PM and see how they can help
MattGrill
The phone I have is an Iphone XR. Do you know if that model would cause a false negative?
slusagm
what phone do you have? maybe that is a false negative.  Ask PM to check or maybe provide refund
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here
Chalupa_Batman
Hey @MattGrill You can ask for a refund creating a ticket this way. However, the options to pick up a SIM card faster is below it.
You can submit  ticket by direct message:
A Customer Service Agent will reply to your community inbox here:
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
