09-25-2023 04:57 PM - last edited on 10-01-2023 11:42 PM by computergeek541
Hello,
How I can maintain my phone while traveling for five months not used, could you have a system of keeping phone number alive whilt traveling.
Shobana
10-12-2023 04:17 PM
Okay I shall do that from oct 17th 85 days I have to pay to make the phone active is it not
10-01-2023 10:26 PM
your current cycle ends on Oct 17th? if so, yes, you start counting the 85 days from oct 17
10-01-2023 10:21 PM
So after the 85 days I will pay for the subscription , now I leave on 15th October so I cannot pay on 17th , would the 85 days start from 17th October?
Shobana
10-01-2023 10:20 PM
When the account was suspended and you need to make a manual payment, simply login My Account and click Pay now and resume service and follow the screen to make payment
10-01-2023 10:16 PM
How is the manual payment done ?
Shobana
10-01-2023 10:12 PM
But when I don't pay will the text messaging work how do I make the $5 payment ?
Please help.
Shobana
09-25-2023 05:59 PM
Hi @SHOBI1
If you're going to be out of Canada for an extended amount of time, the only option port out your number to an app like TextNow and use the app while on WiFi wherever you may be. Keep using the app every few weeks and once you get back, you can port your number back over to PM.
09-25-2023 05:00 PM
@SHOBI1 You can change to the $15 plan and turn off auto subscribe and leave phone suspended for 90 days but in the 85 day make manual payment for 30 days turning auto pay back on , then rinse and repeat for long as you need to be away will cost you $5 a month this way to keep you number
Turn auto subscribe off/on
Or if you know the 4 digit PIN number
*611
09-25-2023 04:59 PM - edited 09-25-2023 04:59 PM
first, PM has no roaming service outside of USA. If you are not going to US, then you will have to pay the plan and keep the account. This is what you need to do to keep alive the account:
PM only allows the account to be suspended for 90 days or your account will be permanently closed, and you will loss the number
So, your option is to temporary suspend the account and reactivate for 30 days before the 90 days deadline
Here is what you can do (assuming your Available fund = $0)
