09-04-2023 03:19 PM
Hi all,
I have some problems with text messaging, my contacts are not able to receive my messages but I’m able to receive messages. Did anyone ever experience this issue? I actually bought a package and all the other services are working fine.
I have tried contacting customer support as well but couldn’t resolve it.
thanks!
10-12-2023 03:10 PM
@ChuongBK Check your private message inbox in a few minutes (envelope top right of this page or click on your avator and go to "messages") and I will send you a number to call for porting assistance.
10-12-2023 03:06 PM
Hi Phil,
I ported in the number from another provider. The number was transferred and paid for the plan. I can make the call, but I could not receive the text message.
10-12-2023 03:04 PM
@ChuongBK Are you porting your phone number into Public Mobile from another provider and not receiving the port authorization text? Or do you mean you can't receive text messages in general?
10-12-2023 02:55 PM
Hello Phil
I have Text message issue. I can not receive text message from other network provider. Please kindly help.
Thank you
09-14-2023 10:33 AM
Hi @Phil_Adelphus, the issue has been resolved now, finally! They had to involve tech support and I can finally use the messaging service! Thank you 😊
09-09-2023 06:57 AM
@loch_ness if you're still having trouble, can you tell us for purposes of elimination
what colour are the bubbles when you try to text someone with an Android, blue or green?
have any of the Android people recently switched from an iPhone
are you sending just words, or attaching files?
does anyone at all on Android receive your texts?
have you tried turning on airplane mode for a few minutes then turning it off again?
09-08-2023 08:40 PM
Yes I have an iPhone and I’m receiving calls and text and I am able to do calls as well. It’s only the texts that I can’t seem to work!
okay will try that and let you know, thanks!
09-08-2023 08:38 PM
Yes you’re correct, I have an iPhone and most of the contacts that I need to send texts have android phones. iMessage works and I’m able to receive texts and it seems like I’m able to send it but they never receive it. And my phone doesn’t send me an error message either which I find weird…
Thanks!
09-08-2023 06:17 PM
This is an iPhone, right? Are all your contacts on Android phones? Unless you have iMessages turned off you should at least be able to send iMessages to iPhones even if not SMSs to Androids.
09-08-2023 06:16 PM
HI @loch_ness
so, you have an iPhone? you did receive message from anyone? And you are receiving calls?
Check the iMessage setup to see if the number is correct
Update iOS, update Carrier Profile, reboot phone and let us know if that helps
09-08-2023 06:13 PM
Did you go to settings, general , about and see if anything wanted to update?
09-08-2023 06:08 PM
I bought the data package of 20gb with unlimited text and calls. And no I haven’t transferred my number from another provider ☹️
09-08-2023 06:00 PM
@loch_ness What package did you buy? Did you port into PM recently from another provider?
09-08-2023 05:47 PM
@Phil_Adelphus yes I do, I’ve tried everything but nothing is working as of yet unfortunately…
09-04-2023 03:54 PM
If you have an iPhone do you have SMS enabled in iMessage?
09-04-2023 03:43 PM
09-04-2023 03:41 PM
I’ve tried it but still doesn’t work after rebooting ☹️. Not sure if it’s because it’s a e-sim…
Thanks though!
09-04-2023 03:28 PM
If Android, try adjusting Chat messages options.
tap Messaging app,
tap 3 little dots top right,
select Settings,
under Chat settings, scroll to "Select default messaging type",
toggle it to Automatic or Text/multimedia msg
For Apple, adjust the iMessage settings:
tap the Settings app,
tap Messages,
turn iMessage off by toggling the switch to grey from green.
09-04-2023 03:21 PM
Have you tried to go to your settings, then network settings and pick Public Mobile and reboot? Instead of having it on Automatic.
