03-09-2024 02:39 PM
03-09-2024 02:42 PM
To access your voicemail you can call your number or just press and hold 1 for about 2 seconds it will automatically go to voicemail.
03-09-2024 02:40 PM - edited 03-09-2024 02:42 PM
When using PM SIM your phone will know vmail number and then pressing on '1' will get you directly to vmail.
If you need to access vmail from another phone or want to change access number go here:
