08-01-2022 09:25 AM
Hello,
I purchased a 1GB add-on but doesn’t show up in my overall allotted data. Is this normal? Maybe not automatic?
thanks!
08-09-2022 10:31 AM
Ticket submitted... thanks again for the help.
08-09-2022 10:18 AM
@mikek33nan OK. So, it is clear that it was used towards the purchase, just that the add-on is no where to be seen
Please open ticket with PM Support for a proper investigation
08-09-2022 10:12 AM
08-09-2022 10:07 AM
Thanks softech for the picture. Mine doesn't show any available funds section. Under Payment History, I see...
Aug 01, 2022
1GB Add-on
Debit
-$15.00
Available Funds Balance: $0.00
Credit or Visa Debit Top-Up
Credit
$15.00
Available Funds Balance: $15.00
I guess I'll start a ticket. $15 is hardly worth my time for the hassle.
08-09-2022 09:59 AM - edited 10-21-2022 12:59 AM
Again, do you see any Available Fund? I wonder if the money is still in the Available Fund
https://selfserve.publicmobile.ca/en/account/overview
If it is there, that means you loaded the money but somehow it wasn't used towards the purchase. If that is the case, you can go back and re-purchase the add-ons
If the money is not in the available fund, open ticket with PM Support for a investigation:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-09-2022 09:55 AM
Thanks for the help but I still don't see it under the Add-On Usage in the Plan and Add-ons section. I can see debit charge under my Payment History. I use Safari but also tried Firefox. Firefox won't let me log in to my account even in private mode. After entering my account credentials, just shows an animated gif of a caped man holding his phone in the air... lol.
What do I do now?
08-01-2022 05:30 PM
@mikek33nan - if you were asking if the 1GB gets added to your plan data, then no, it does not. It will show up as a separate line item than your plan data.
And it should be immediately if you had the funds to add it to your account.
If you believe you purchased it successfully, try logging into your account through a different browser or a tab in incognito mode, could be a finicky thing that you are not seeing it right away.
08-01-2022 09:30 AM
Login to My Account, the 1GB add-on you purchased will be with the Add-on Usage section of the main Overview page or Plan&Add-on page.
If you still don't see it there, Check if you see Available Fund = $15 or more, that could mean the amount was just loaded and didn't used towards the purchase
And check Payment History ,See if there are 2 separate lines, one about the payment you loaded and the other one about how the money was used (towards the purchase of the add-ons).
