US roaming
10-10-2024 02:44 PM
My data roaming work for a few days now nothing I bought a 3gb 15 day addon
Will not connect to a network it finds networks I am 4 g phone android
Add-Ons
10-10-2024 02:46 PM
@2525 Try to manually connect to T mobile / AT&T or Verizon see if they helps and test in different area also ensure your 15 days hasn’t run out
10-10-2024 02:46 PM
hi @2525
did you mean it works for a few days and now stopped working? or it does not work at all?
and for US roaming, make sure you turn on roaming mobile data on the phone
change the network connection to manual and try all 3 networks: T-mobile, AT&T and Verison. Try each one and see which one works
