Where are 3G plans?
05-24-2023 10:17 PM
I can only see these plans. Where are the $15 and $25 3G plans? They are removed?
Plans
05-26-2023 09:54 AM
HI @Edsport I login now, I still see all the 3G plans.
Try using Incognito/Private/Secret mode to login
05-26-2023 07:27 AM
Yesterday i clicked on "change subscription" and the 3G plans was shown, today i clicked on "change subscription" and the 3G plans does not show. Are they still showing for other people?
05-26-2023 06:25 AM
05-25-2023 08:45 AM
05-24-2023 10:54 PM
log in to your account / Change Subscription......you should see the 2 available 3G plans.
05-24-2023 10:45 PM
the same question haha
05-24-2023 10:20 PM - edited 05-24-2023 10:22 PM
log in to your account / Change Plan Subscription......you should see the 2 available 3G plans.
05-24-2023 10:19 PM
no worry, they are still there. PM just didn't post them all
When you activate (or if you are exiting subscribers, login to My Account, go to Change plan page) , both $25 and $15 plans will be there for you to select.
05-24-2023 10:19 PM
they are still there, just not displayed on the main site at this time, when you sign up via the app the plans will be visible.
