Rewards not applied ??
lina81
I changed my plan to the new $39 20gb and no awards (old rewards)
are being applied on my upcoming payment !
HI @lina81  did you use Change plan now?  if you did, it is normal they charged you the full amount without rewards for that one time change.
But if you want to confirm, as you don't see it in the upcoming payment, submit a ticket with CS agent at:   https://widget.telus.tiia.ai/publicmobile/publicmobile.html
lina81
I just checked my account and still no rewards being applied to upcoming payment !
How can I get help with this ?
TinTin_Cap
Yes, I just changed to the $39 plan with an upcoming renewal date when my current plan expires, the upcoming charges showed my current rewards that will be taken off when renewal date comes.
hairbag1
@lina81
any due Rewards will be applied at next regular plan renewal. 30 days after current plan was activated is your next renewal date.
@lina81    If you opted for Change at Next Renewal then your rewards will applied.  Try logging in again via incognito/private mode on browser as you might be viewing old information.
For immediate plan changes, no rewards are applied nor partial refunds for unused days left in the plan.
