02-18-2021 04:36 PM - edited 01-06-2022 02:08 AM
I activated a new public mobile sim card with a new number and I used whattsapp for an hour and I got banned I contacted whattsapp support and they said I have a unsupported number what do I have to do to fix this issue they got it working 3 times but I keep getting banned after an hour..
Service
02-19-2021 06:21 PM
What a ridiculous policy. How can anyone outside of the operator match a SIM card serial number to a phone number?
02-19-2021 04:11 PM
@darlicious wrote:Hmmmmm....I wouldn't be giving up my sim card # so easily.
@darlicious Agree or not, that is what is required by whatsapp.
02-18-2021 10:17 PM - edited 02-18-2021 10:24 PM
@LurganIeUk wrote:Just a dumb question.
PM has free texting....why use whatsapp
@LurganIeUk
There are many reasons why to use WhatsApp, Viber or any other chatting app.
Here are some of mine:
- No need to worry about cost (maybe less now, but few years ago it was a thing), it is using internet.
- No roaming when you are traveling. Just use WiFi
- Much better interface
- Great group supports
- More options do send various types of files
- 'Free' way to contact people all over the world
- MultiPlatform support (iPhone, Android, etc)
- Longer messages
- Ability to use computer for texting. Such a time saver. I barley ever use it on the phone actually.
- and so on..
So, while you could probably get away with SMS in some cases, it is just easier.
02-18-2021 07:54 PM
I sent them a picture of the card where the SIM card came in,not the actual SIM card
02-18-2021 07:40 PM
02-18-2021 07:38 PM
02-18-2021 07:37 PM
Happy to see you've been sorted. Just an FYI to tag someone just tap the "@" key and a box will pop up with usernames. If the one you want doesn't appear just keep typing their name out til it does.
02-18-2021 07:33 PM
Done
02-18-2021 07:26 PM
@Randy83 wrote:I activated a new public mobile sim card with a new number and I used whattsapp for an hour and I got banned I contacted whattsapp support and they said I have a unsupported number what do I have to do to fix this issue they got it working 3 times but I keep getting banned after an hour..
Press the 3 vertical dots and edit your solution.
02-18-2021 07:24 PM
Ok sorry about that I’m new to support forums
02-18-2021 07:16 PM
Yes for sure they are a pain but trying to get the groups to switch to signal is next to impossible
02-18-2021 07:16 PM
@Randy83 :Thank you for marking your thread as solved, but you not supposed to mark your own post as accepted solution, since @hTideGnow post right above your mentioned same advice you should click the accepted solution button above his post instead.
02-18-2021 07:14 PM
I think I got it figured out it must have been that I tried to join too many groups at once, Thanks for The info
02-18-2021 07:12 PM
@Randy83 :Now that it working without you joining all those groups definitely the problem was joining all those groups so fast, try joining a few each day until you join them all again.
These apps like whatapp and facebook etc are such a pain and not worth supporting anyways, other apps like Signal Private Messenger would never give users this kind of crap.
02-18-2021 07:11 PM
Mostly for groups and I’m using wifi so data usage is not a concern
02-18-2021 07:11 PM
02-18-2021 07:09 PM
02-18-2021 07:07 PM - edited 02-18-2021 07:35 PM
Yes i was wanting to join about 70 groups but after joining about 25 or 30 it started banning me I have since quit joining and after 3 hours I’m still on WhatsApp, so trying to join all the groups must have flagged my account and banned it, I’ll just join a few every day until I’m in all the groups I want
02-18-2021 06:40 PM
@Randy83 wrote:I have stopped going into the groups for now and it’s be 2 1/2 hours and WhatsApp is still working so the issue must have been joining all the groups
you know what. did you say you add 75+ groups? maybe you added too many in a day and the Whatsapp monitor thought you are Spamming the system?
when you are ready to join, maybe start slow..
02-18-2021 06:37 PM
@hTideGnow sorry, no idea.
02-18-2021 06:29 PM
02-18-2021 06:27 PM
Yes correct
02-18-2021 06:12 PM
@sheytoon , thanks for the link .. very useful page. just a question, What is OCN?
02-18-2021 06:04 PM - edited 02-18-2021 06:06 PM
Maybe WhatsApp doesn't recognize the exchange for that phone number. It does show as Telus Mobility when you select your area code here so it's a valid Telco number that is not voip based.
02-18-2021 05:59 PM
@Randy83 wrote:The only thing I can figure out is I’m trying to get into about 70 different WhatsApp groups that I have on my other phone unless that sends a flag and gets me banned
Just hold on and do not get into any groups for now, i guess.
Also, I wonder if you got an recycled number and that number had issues with Whatsapp before, or have issue with those Whatsapp group before..
as you said, this is a new number you got from PM. Maybe you can try to request a new number and see how it goes?
02-18-2021 05:48 PM
02-18-2021 05:42 PM
02-18-2021 05:33 PM
@Randy83 , that's interesting. I swap back and forth from my phone and tablet, and one would think that WhatsApp would think something is up. I look at the screenshot, hoping it would reveal anything fishy. I wanted to know if there was a scam or something, so I Google it. There was an article a week ago, about being banned.
From what I can gathered:
- In most cases this banning of a number is automated. So if someone has been banned by WhatsApp, what does that mean?
- Well, it means you did something that the Facebook-owned app did not like. WhatsApp bans its users when it senses a slight violation of its terms and conditions.
- Also on occasions, if a user is using an unsupported version of WhatsApp instead of the official WhatsApp app, they will be temporarily banned from using the messaging app.
02-18-2021 05:33 PM
Yes I can verify WhatsApp and it works for an hour then I get banned again
02-18-2021 05:27 PM
Yes I can verify and it works for about an hour then I get banned again and I’ve reverified it 3 times already with WhatsApp support
