05-23-2021 01:55 PM - edited 01-06-2022 02:08 AM
having issues activating my new sim message stating incorrect MEID and someone will contact me but no one has. how do I fix this?
05-23-2021 04:41 PM - edited 05-23-2021 11:05 PM
@Michaelvieira wrote:having issues activating my new sim message stating incorrect MEID and someone will contact me but no one has. how do I fix this?
There's actually a mistake in that text message. MEID is no longer used in Canada. MEID was previously used because of of manufacturers running low on ESNs. They are CDMA device identifiers. It's the IMEI that is actually being asked for.
05-23-2021 03:48 PM - edited 05-23-2021 03:50 PM
Did you allow the Public Mobile system to generate a new number, or are you porting in a number from your old provider?
If you are porting a number, and the information you provided was insufficient or inaccurate, Public Mobile will need more information from you to complete the number transfer.
Use SIMon the chat bot (white bubble in lower corner) to contact the Moderators.
05-23-2021 02:49 PM
You're always able to activate your SIM with a (temporary) Public Mobile number, and transfer your number later in... just in case you're looking to activate within the current promo period. If you activate first with a Public Mobile number, you can always port/transfer your number afterwards. (There's also a Porting team you can actually call if you still have troubles too.)
As for IMEI, it may need to be the original IMEI registered with your old provider (in case you changed phones). Another way of transferring/porting your number is using your Account Number from your old provider as opposed to the IMEI.
05-23-2021 02:36 PM - edited 05-23-2021 02:37 PM
Check your phone setting to double check if you entered the correct IMEI#.
For iPhone go to settings>general>about.
For Android go to settings>about phone.
If it looks correct, you will need a moderator for assistance by clicking on SIMon Chat button and submit ticket to contact moderator or click the envelope icon and message moderator.
05-23-2021 02:05 PM
Transferring Or Changing Your Phone Number, Click Here
or
Number Transfer (Port) Troubleshooting, Click HERE
or
Choosing Or Transferring A Phone Number During Activation, Click HERE
if you still not working with you,
you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
05-23-2021
02:02 PM
10-09-2023
08:46 AM
05-23-2021 01:57 PM - edited 05-23-2021 02:05 PM
@Michaelvieira where did it say someone would contact you?
Did you get charged for a SIM activation, and enter incorrect info. perhaps through a port?
If so, Moderators can help.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
EDIT:
If you want the MEID number, ignore the last digit in the IMEI number. There are multiple ways to find your IMEI number. You can dial the universal IMEI *#06#. You won't need to press the call button as it will automatically pop up on your screen.
