09-12-2019 04:38 AM - edited 01-05-2022 07:02 AM
09-12-2019 05:22 AM
Once you deplete your data then it stops. You would either have to buy an add-on for more data or wait until your renewal date
09-12-2019 04:46 AM - edited 09-12-2019 04:48 AM
@Raf414 once it's all used up it will stop working! You can either purchase a data add on that will roll over every month until used up or you can renew your plan early to start the plan data again. Keep in mind you you renew early and want the same plan you'll have to message the moderator_team, if you want a different plan you can do it in the self serve account. Also you can just wait until the renewal happens automatically at the end of your 30 days and it will renew your data and you'll have your in plan data again!
