03-31-2019 03:11 PM - edited 01-05-2022 07:02 AM
I have a question. I am having trouble with my iPhone so I am getting a new one. Will I have any trouble with my public mobile SIM card when I put it into my new iPhone??
03-31-2019 03:53 PM
Ensure to check your phone compatibility at this page. If it is compatible you should be good. Enjoy..
1. Check your phone’s compatibility
Enter the IMEI number on your device and we’ll let you know if it’s compatible with our network. For more information about network compatibility, click below.
https://www.publicmobile.ca/en/on/get-started
03-31-2019 03:37 PM
@Cpark81 wrote:I have a question. I am having trouble with my iPhone so I am getting a new one. Will I have any trouble with my public mobile SIM card when I put it into my new iPhone??
The current sim cards that are sold by Public Mobile and retail locations are multi-sized, so you no longer need to worry about getting the correct version (unless the store has some really old stock).
As stated earlier, your device needs to already been unlocked (or be a Telus/Koodo device). For some models of iPhone devices, you might have to find work-arounds to get set the APN settings and get cellular data working.
03-31-2019 03:33 PM
As long as your iPhone is unlocked you should have no problem. All you need to do is put your sim in the new phone.
03-31-2019 03:15 PM
Thanks I greatly appreciate it! :smileyvery-happy 😊
03-31-2019 03:13 PM
Hopefully not..I did it 3 times and never had problem
If you have problem with the new one come back here.
