08-30-2022 06:25 PM
I am on the $135 / 90 day / 6GB plan from a few years ago. I am running out of data more these days so I want to change my plan.
1. How can I tell if I have 3G or 4G data now? All it says for my current plan is "6GB data Data".
2. What is the difference in 3G vs. 4G data speeds?
Thanks
08-31-2022 11:40 AM
Doesn't matter. Anybody can ask about any account as long as they can verify account information.
Be aware that we often see incorrect information from these agents. I just had one saying my basic plan does not have data so just stay on 3G. No it doesn't. But it has a bunch of add-on data that is on 4G LTE.
So it can often end up that information you get here is more accurate and even more up to date than what you could get from an agent. And faster. The agents are obviously needed to do account things.
08-31-2022 11:36 AM
@call-151 they might still be able to deal with you with your current Community account
if no message from PM Support, I would message them and let them know you did complete the validation
Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-31-2022 11:34 AM
Well, my private message inbox is empty, but it probably doesn't help that this is my wife's PM account that I'm asking about. She doesn't have an account in the community forums.
08-31-2022 11:24 AM
It's good CS agent steps in, but I really don't think the should post the link here. At max they should just say "check your inbox for authentication link"
And sometime, many times, CS agent private message the wrong person (ME instead of those OPs) and offering help. Again,it is good they step in, but they should be more careful. Read the post. LoL
08-31-2022 11:21 AM
@call-151- Not here. Have this conversation in private messaging. The agent really shouldn't've replied here.
08-31-2022 11:18 AM
I have done the authentication procedure.
Thanks.
08-30-2022 09:56 PM
I suggest sticking with 4g as the 3g plans have been nerfed(slowed down). the experience is not good. either way one can always change plans if one is experiencing issues with the 3g plan.
08-30-2022 07:35 PM - edited 08-30-2022 07:37 PM
Any plan that mentions 3G in the description will be 3G. If there's no mention in the description then by default that is 4G.
So-called 3G is set to 3Mbps. The new 4G is set to about 100Mbps. YMMV as always.
Adding - lol do a little catch up reading and see that nobody is saying that and then there's dabr at the same time. 🙂
08-30-2022 07:35 PM - edited 08-30-2022 07:35 PM
@call-151 If you don't see 3G speed mentioned in your account, then you are on 4G plan (grandfathered). IIRC all 3G plans do mention 3G speeds.
Also keep in mind, since your plan and 90 day payment timeline is no longer offered, any change to one of the current plans will mean you cannot go back to your discontinued plan but will also be on 30 day payment cycle. Of course, the newer plans, especially the newly introduced 4G plans, might offer better value if you are depleting your available data before renewal.
08-30-2022 07:16 PM
If you use a lot of data, and your paying that much price for 90 day what i think much better for you to change new plan with 30 day, with a higher data if you user a lot, and check out all price Plans (publicmobile.ca)
with the budget you would like to pay each 30 day and how much need data.
08-30-2022 07:04 PM
Thank you I will try contacting support. I guess I should have done that first.
08-30-2022 06:55 PM
you right not showing... but i found this 6GB @ 4G LTE / 90 days plan = $135 - Page 2 - Community (publicmobile.ca)
your speed 4G,
if you wan to contact PM support team by private message CS_Agent to check it in your account.
08-30-2022 06:48 PM
Yeah I can't find any text that says 3G or 4G, on my account. Maybe I'm missing something.
08-30-2022 06:46 PM
08-30-2022 06:44 PM
08-30-2022 06:37 PM
what plan is showing to you 3G/4G speed. or can you provide a screenshot and block person info.
you running out of data, and your data is off now or you just saw at your account data usage full.
08-30-2022 06:37 PM
Thanks for the quick reply guys 🙂 If I'm on 3G now then I will probably continue with another 3G plan. The $40 for 5GB is a better deal than what I have now!
08-30-2022 06:31 PM
Since you are on a grandfathered plan, you are on 3G.
If you are not streaming movies or video, 3G is good enough for everyday usage.
08-30-2022 06:30 PM
I think your plan is one of the grandfathered plans which has full LTE speeds, so it's a 4G plan most likely.
3G speeds are around 1-3MB/s whereas 4G speeds are close to or above 100MB/S
