What is the order in which Data Add-Ons will be used?
JoeCanadian
As a long time customer of PM, I have a few non-expiring data-ons I received as Promos.  If I exceed my monthly data amount, will these older, non-expiring data add-ons be used first before any of the recently added 240GB loyalty bonus that does expire in 150 days is used?
NerbasA
 Expiring data gifts are going to be used first as this question was asked previously. You can take a screenshot of your data usage on your account while away from wifi to confirm this.
hi @JoeCanadian
CS agent answered me earlier saying once the regular data are used , the special bonus will be used before other add-on from before (those without expiry)
Dunkman
@JoeCanadian
According to Public mobile, the 240 GB (expiring ) data add on will be used before any non expiring data add on.  One customer verified that this also happened with his/her account.  Bonus data add on (expiring) was used before the older non expirary ones.
Yummy
First your plan allowance data is used
Second 'points' bonus data
Third purchased add-ons
Fourth holiday bonuses
TheSterlinger
Add-one are used based on the whenever your current plan data is finished. The order of the add-on is based on expiry (the add-ons that expire will be used first).
@JoeCanadian  The expiring data add on will be used first then your non expiring data after that . Once your plan data bucket is used
