What happens to my 3g data plan?
NoFixedAddress
I'm on the $25 5 GB data plan (data in 3g) and I'm in Manitoba.  What happens to my plan when 3g shuts down? My phone is Volte capable
@NoFixedAddress
Since your phone is 5G (data) and VoLTE (for calling) then I wouldn’t worry about 3G decommissioning.
It will only affect those who have older phones.
hi @NoFixedAddress
your phone is 3G capable but have to be on PM's VoLTE whitelist to use VoLTE
https://www.publicmobile.ca/en/on/get-help/articles/volte
and you are still on a 3G plan? is that a $15 plan ?  there is a new $15 4G plan, check your My Account's Change Subscriptoin page
DennyCrane
The 3G network shutdown has nothing to do with your 3G plan. All plans are permitted to access all available networks (3G/4G/5G); your plan simply dictates max speed they throttle you at.
Having said that, have you looked to see if there are better plan options available in your account?
