07-07-2025 09:58 PM
Hello,
I keep having instances where I have at least 2 "bars", and it says I'm on 5G, but I'm not getting any data and there's an "!" next to my bars. This seems to be intermittent, and will come and go when I'm in the same area. Any ideas what could be causing this? APN settings?
Thanks!
07-10-2025 02:55 PM
Service was good until now, it's just been happening intermittently but I'd say started within the last month. I have indeed tried rebooting the phone but that didn't work. No data limiter, but I haven't tried changing the network mode yet, that's an interesting thought. Next time it does it I'll try that and report back!
07-10-2025 02:54 PM
Thanks for the thought! But yes I always have plenty of data left, never even seem to use 50% of it.
07-07-2025 10:03 PM
did you login My Account and see if you have any data left for this cycle?
07-07-2025 10:03 PM
HI @Brammer22
did you just join PM today ? or service was good until now?
try reboot the phone, try Reset network settings
also, try changing network mode to 4G or LTE and check if it helps
and make sure you have mobile data enabled, make sure you disable data limiter
