08-27-2018 04:16 PM - edited 01-05-2022 05:31 AM
So far have wasted $15 last month and again this month ready to switch providers unable to use data would like to go back to my $25 plan the $40 plan is useless to me
08-27-2018 07:45 PM
Glad to see that Randall1 got his problem sorted. I'm on month 2 and still don't have data. My APN settings seem to be locked, mods haven't figured out an answer yet (they're trying), and Umidigi tech support seems to have taken a flier....
Very frustating.
08-27-2018 06:52 PM
I had no issue with my LG q6, until I messed things up on my own 4 days in.
ive already done factory reset twice. But I’m good now. Lol
08-27-2018 06:15 PM
glad you got it figure out. I had the same issue before. There must be something wrong with LG's software.
08-27-2018 05:22 PM
Yes this is a great community to provide help when needed. Thank you for coming back to confirm every thing works correctly now
08-27-2018 05:20 PM
Thanks for coming back to say that. And I find peer (with mods) forums are often much better than call centres, even when a call centre is provided. PM has a particularly good forum (their call centre was good back in the day, but I only called once with a simple request on a grandfathered plan, and I suspect I was referred there by the people here :).
=aw
08-27-2018 05:19 PM
Great to hear @Randall1! ![]()
Definitely keep coming back to the Community. Once you get a hang of how it works around here, I'm sure you'll want to stick around. There are lots of helpful people here plus there are moderators who work behind the scenes to help with account related issues, etc.
08-27-2018 05:15 PM
Think it works now did what the instructions said can't believe I figured it out thank u for the help
08-27-2018 05:14 PM
08-27-2018 05:10 PM
If you search for "LG g5 network reset" there are many tutorials found online. It's just a few steps. Sorry to hear you've had problems with data, but there are many knowledgable people here that can help. I know you want a phone number to call, but that's not how it works with Public Mobile. Give the Community a chance to help you... ![]()
p.s. don't type your reply in the Message Tags box. That's why nothing is showing up in the main body of your post.
08-27-2018 05:05 PM
@Randall1, please post your message in the message box instead of the message tag. It is a lot easier to read this way. I have tried to help you with setting up the data on your phone. Can you at least provide feedback on whether it is working or not. If you are insistent on changing back to your old plan without loss of payment credits, you will need to take that up with the moderator team. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
08-27-2018 04:39 PM
08-27-2018 04:36 PM
Im using a LG g5
08-27-2018 04:31 PM
For LG phones, sometimes a network reset is needed to fix data connectivity issues. This is kind of like a soft reset so to speak and is different than a full factory reset. Network reset clears the network related data from the phone.
08-27-2018 04:25 PM
08-27-2018 04:24 PM
08-27-2018 04:20 PM - edited 08-27-2018 04:21 PM
@Randall1, what seems to be the problem that is hindering data usage. Can you describe the hardware you are using and other relevant conditions so that we can better assist with troubleshooting. Often the problem is with setting up the APN on the phone. Check this site out for the proper APN settings.
