Want to change my add on
Kimatcan
Hi there!
I can’t use my add on for 3gigs data and I just found that is for US roaming.
so I want to cancel or change my add on.
How can I do that? Please help me!
thanks!
HALIMACS
@Kimatcan
In the case of an accidentally added purchase like an add on, so long as the item hasn't been used, public mobile will generally reverse it and apply the funds that were used to purchase on your accounts Available Funds.
That way, it can be used for the correct purchase or a future renewal.
@Kimatcan PM is prepaid provider and usually do not provide refund.  However, they might help for honest mistake like this.
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@Kimatcan  You need to ask support about this
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
LoveNature
Hi @Kimatcan
submit a ticket with SIMon Chatboth
typ: Agent
and Click, Contact Us
then Click, Other
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
