Voucher not accepted
cateye
$20 Voucher not accepted, said to see Public Mobile community online. How can I add this $20 to my account?
Thanks...good information.
cateye
Moderator was able to solve it. They added the voucher to my account and said there was a glitch with the vouchers at that time.
hairbag1
You can try calling 611 and follow the prompts to add the vouchers to your account. Sounds like maybe a system wide issue with loading vouchers these days. Sometimes the retail sellers of vouchers neglect to activate them for several hours after the sale.
Good luck.
@cateye wrote:
Thank you
I'll post here if they're able to resolve it
@cateye  PM is experiencing problems with processing vouchers. If you contacted the moderator as recommended and provided them with a copy of the receipt or the 12 digit PIN they will activate it for you.
cateye
Thank you
PMFanatic
@cateye You can call 611 to assist or if that doesn't work, I would recommend messaging the kind folks at the Moderator_Team via this link to investigate your account and to provide some additional insight into your issue.
It helps to provide a detailed description of your problem and what your resolution goals are so they can best assist. If you are having troubles contacting the Moderator_Team, refer to the following knowledge base link. Expect a response within 1 hour or up to 48 hours depending on volumes...
Best of luck!
