11-28-2020 03:09 PM - edited 01-05-2022 05:34 PM
Hi,
My account was deactivated, because I was late by 2 days to top it up with my vouchers. I have tried to put in 2 vouchers to re-activate, but it does not work. Please help.
Luana
11-28-2020 03:56 PM
You can consult the Voucher Catalogue to see if your vouchers are represented and learn more about them. Or you could share where you bought them and we could advise from there.....its easier to add them thru 611. After dialing and connecting.....press (1) and (1) again. Enter the 12 digit pin #. If its accepted you will recieve a text ftom pm almost immediately confirming it has recieved a payment.
11-28-2020 03:20 PM - edited 11-28-2020 03:21 PM
When did you buy the vouchers? Just now? Ones at gas stations / corner stores sometimes take 15/30 min or an hour to become active. Other top up cards apparently some take up to 24 hours.
Check the voucher closely there are usually two 12 digits. One says PIN and the other might say voucher #. If you dial 611 use the pin number. If you're online in your account making a payment use the voucher number. Of course try vice versa also to see if you can get it applied.
Let us know!
11-28-2020 03:15 PM
@luanabbrito2807 wrote:Hi,
Luana
Some vouchers take up to 24 hours to activate. Try calling 611 to add it.
If still problems contact a moderator and they will add it for you.
Here’s when and how to contact the Moderator Team:
11-28-2020 03:13 PM
If you recently purchased them, it can take up to 24 hours for them to be activated.
