01-06-2025 11:02 AM
01-06-2025 12:38 PM
I purchased 120 with vouchers it only excepted one ? The rest ain’t working says account suspended
01-06-2025 12:38 PM
Yes I signed into my account added vouchers says account is suspended won’t update account ?
01-06-2025 11:59 AM
@Jaywood Just to be sure, are you an existing customer or just signing up? If you're just signing up for the first time it can't be done with vouchers although subsequent payments can be made that way.
01-06-2025 11:20 AM
Trying using the PM app to add a credit instead of browser and make sure the postal code matches the credit card address one.
01-06-2025 11:20 AM
Go to payments and click on Redeem... Use computer
01-06-2025 11:15 AM
@Jaywood have you tried by dialling *611 from your phone? Are you able to login to your Public Mobile account, you should be able to do it through there as well. If you are still having trouble you can open a ticket with a support agent.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
