05-19-2023 10:43 AM
Others have said my voicemail is full. However, when I dial in, there are no messages. Any solutions for this issue would be appreciated. Thank you
05-19-2023 04:29 PM
@sirhcretso1 wrote:Others have said my voicemail is full. However, when I dial in, there are no messages. Any solutions for this issue would be appreciated. Thank you
When you listen to the messagers are you deleting them? If when checking the messages, you simply hung up, the messages would get saved even if you don't tell it to. Please check for saved messages and manually removed them.
05-19-2023 11:46 AM
HI @sirhcretso1 should be ok then
I think the most useful test is to call yourself from another phone, if your phone with PM sim card rings, no problem with porting then
For the voicemail, maybe you need PM support to help to reset your whole voicemail mailbox
Please submit a ticket with them:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
05-19-2023 11:44 AM
I have been with them only 1.5 months or so, and I have received a few voicemails to my Public Mobile...would that mean that the porting is working, or could there still be an error? Thank you
05-19-2023 11:32 AM
@sirhcretso1 - do you get the same message when you call your number?
05-19-2023 10:49 AM
hi @sirhcretso1 did you just join PM and requested porting your number? if so, likely the porting was stuck and people still calling your old VM
