03-05-2023 11:50 AM
The voicemail notification is stuck despite multiple attempts to get it resolved with @CS_Agent. I have tried to following:
- Reset voicemail password
- Reset phone services app (Samsung) - notification reappears after restart
- Did a network reset
- Restarted phone multiple times
- @CS_Agent did a refresh on their side
- Inserted sim into another phone and the notification appears as soon as the phone boots up
At this stage I think my only option is the cancel the service. Anyone else has any answers? Should I give up because @CS_Agent can't seem the solve the issue on their side even though I know it is the Public Voicemail system spamming my phone with the notification.
Other
04-13-2023 11:39 AM
I am having the same issue, Did you just chat with public mobile via online or phone? do they have a tech support number?
03-12-2023 06:38 PM
@esjliv Sorry for the delay. I made some other tests. Everything worked fine with my IPhone 5S and my IPhone 6. A dot appeared after a message came. And when I deleted it it disappeared as it should.😁 with my IPhone 12 no dot at all after a message is left. Why upgraded our phones??? 🤪🤣 And I don’t want to reset every day my voicemail on the back so I decided to let go this problem.
03-12-2023
09:10 AM
03-15-2023
04:12 PM
Luddite
Good news, my issue has been resolved on Public Mobile's end. Tech support had to reset my voicemail and left me a voicemail. The stubborn notification went away after I listened to the message.
[ok then, a bug that vm reset by PM resolves ..... Luddite]
03-10-2023 03:38 PM
03-10-2023 03:25 PM
@esjliv No no they WERE there!!😉
03-10-2023 02:58 PM
@heinmbadenhorst wrote:Doesn't that actually prove that it is not your phone as the issue is present on another phone when inserting the same sim?
Yes @heinmbadenhorst , I see your point. If @Lieux tried their SIM in another phone and notifications did not go away, then it doesn't seem like a device issue. Unless Lieux meant they were not there...?
Still, I'd try another provider's SIM card in your phone, if you can, and test that. See what happens.
03-10-2023 02:54 PM
HI @heinmbadenhorst if putting the sim in iPhone 6S and notifications come, it proves it is not the network but could be a device issue of the original phone or the iOS version there.
03-10-2023 02:53 PM
@heinmbadenhorst That’s not a public mobile problem for sure. Where is the real problem I don’t know.
03-10-2023 02:51 PM
03-10-2023 02:17 PM
03-10-2023 02:14 PM
@heinmbadenhorst And…I tried my public mobile Sim in my old IPhone 6S and the notifications were there. So that’s not a Public mobile problem.🤷♀️ Good luck.
03-10-2023 01:46 PM
HI @heinmbadenhorst Yes, this has been a problem for some customers for some time. However, it might not be a Public Mobile problem, but a problem with the device. I check around and there are so many posts about this problem with different carrier. And sometimes it does not happen right a way, it might happen shortly after you joined a new carrier
03-10-2023 01:32 PM
@heinmbadenhorst wrote:Okay so after numerous attempts to try this resolved on PM's end, they keep assigning me to new CS agents who basically tell me to do the same thing. I have given up and unfortunately I will cancel my service at the end of the month 😞
I am not confident this is an issue on Public Mobile's end @heinmbadenhorst .
A good way to test is, can you borrow someone else's SIM card from another provider and put it in your phone? See what happens when you send a message to there voicemail and if the notification disappears or not after listening to the message.
03-10-2023 01:22 PM
03-05-2023 01:44 PM
I got them to open a tech support ticket. Will see if they're able to resolve and report back.
I forgot to mention that I started having the stuck notification about a month ago after I activated an extended absence greeting. I have since disabled the extended absence greeting to no avail.
03-05-2023 12:28 PM
@heinmbadenhorst I am sorry with you…I have problem with my notifications on my phone application. I tried many things too but nothing helped till now. Except to disable badge notifications for a while and enable it later. And another trick is to phone my voicemail with my phone and erase all my messages included some I just erased. But that’s not a solution every time.🤷♀️ If you google this problem on internet you will read that’s a problem with different companies and different phones. Sorry I can’t help you but you know now that’s you are not the only one who struggle with that.
03-05-2023 12:14 PM
@heinmbadenhorst wrote:I don't agree that this is an issue on my side. Why would the same issue appear on another phone one I insert the public mobile Sim?
@heinmbadenhorst OK, I guess I read it wrong what you said
But check around different forums/Communities, it is not just a Public Mobile issue
Did the Agent tried to reset your voicemail mailbox? ask them to try, it could resolve it , at least short term
03-05-2023 12:12 PM
03-05-2023 12:05 PM
also, check @Lieux's experience
Another idea is to disable badge notification first, then reboot the phone, and enable it back again
03-05-2023 12:00 PM
I interpret your last bullet point that the problem followed the service.
03-05-2023 11:57 AM
as you see " Inserted sim into another phone and the notification appears as soon as the phone boots up", this is not really a carrier issue.
There are posts about that here on this community as well as on other communities or forums. It does not look like a carrier only issue, so, you could end up wih tthe same even you change carrier 😞
did agent try to reset your voicemail mailbox? It could work briefly but again, we saw that this could come back and not a long time fix
