Voicemail not accessible
blixner
Tried pressing 1. "Hi, public mobile here. Sorry, your call cannot be completed as dialed..."
Tried *86 - same thing...
kaytus
@blixner did you active your vM?
Meow
Try calling vmail access number from another phone or even from your mobile phone.
Press and hold '1'. Check which number is stored as access vmail number on your phone.
dabr
@blixner   To listen to your voicemail, you need to long press the # 1 for a second or two on your phone's keypad and not just press it.
Quigley
@blixner   Try calling your mobile phone from another line and use # to retrieve VM.       You'll need your PIN number though.
