08-19-2023 10:01 PM
The voice message icon will not go away. I have no messages.
Can someone help 😫
08-20-2023 12:15 AM - last edited on 08-29-2023 04:24 PM by Luddite
I clicked on force stop in the voice-mail setting and finally got rid of that icon.
[ ✅ self help wins ...... Luddite]
08-19-2023 10:46 PM
Check the settings on your Samsung S23. Go to Setting>Apps>Phone>Notification>disable Allow notifications then enable Allow notifications or click on Allow sound and vibration and click on either Badge or Pop-up.
08-19-2023 10:32 PM - edited 08-19-2023 10:38 PM
iPhone or Android?
if iPhone, what iOS version you have?
Can you press and hold the icon with the badge and select clear Badge?
or press and hold the icon with the badge select App Info, select Clear Data
08-19-2023 10:16 PM
08-19-2023 10:15 PM
I've experienced the same thing once or twice. Only way I could get rid of that erroneous notification was to reboot the cell phone. It's a nuisance but it will go away...eventually.
08-19-2023 10:11 PM
I have an Samsung S23
08-19-2023 10:04 PM
@Tamram Is this iPhone ? Do you have the latest software update 16.6 some have said it has helped. Other have said they had support reset the voicemail and that helped
private message To CS_Agents click
VVVVV Link below VVVVV
