Roaming is not working
VeraArt
Hi there,
I added add-on data for us. Roaming is on on the phone, it shows lte and provider but there is no internet. I reboot my phone, checked my account - everything seems fine. Why it does not work?
10 REPLIES 10
VeraArt
Nothing helped and I got back to Canada. It turned out I bought addon data for Canada not for US.
If your network mode is set to 5G then change it 4G LTE. There was a report earlier about doing that and data worked.
That is weird. This should have worked. I think the next step is to as a CS Agent for assistance.
VeraArt
Tried both. Turned off automatic, selected Tmobile and reboot - no internet. Did the same for ATT. Both networks show excellent reception
JRod
Makes total sense! I’ve edited my comment to reflect this. Thank you!
@JRod wrote:
Hello @VeraArt
If you go into network selection, turn off automatic and try manually selecting Public Mobile or T-Mobile then reboot.
When itn the U.S. the customer shouldn't be looking for or selecting the Public Mobile network. t wouldn't be in the list.  Hypothetically, if the custoemr is near the Canada/U.S. border, manually selecting the Public Mobile network would actually disable all U.S. roaming services.
That's not the point @VeraArt   You need to go into your settings, turn off automatic and THEN choose Tmobile or ATT and then reboot.
VeraArt
It’s already on T-mobile
Chalupa_Batman
@JRod is correct. This would be my advice as well. Try one service provider first. If that doesn't work, try the other. Report back on your findings please.
JRod
Hello @VeraArt
If you go into network selection, turn off automatic and try manually selecting T-Mobile then reboot.
