01-06-2022 04:12 PM
01-06-2022 05:57 PM
@walker1 wrote:Yes, just call your phone number and press * during your message. Then enter your pin number 😉
To clarify, it isn't the Public Mobile account PIN that needs to be entered. The chosen voicemail password can be different and is set up to whatever the user chose.
01-06-2022 04:23 PM
You can also access your voicemail from a landline or any other phone line, by dialing your 10-digit phone number, selecting ‘Send’ or ‘Call’ and then pressing ‘*’ to skip the system greeting.
01-06-2022 04:16 PM - edited 01-06-2022 04:21 PM
Yes, you can! And it is good feature for $15 plan as accessing vmail will use your minutes.
Call vmail number (647-580-4001), enter your PIN and you have access to vmail and all options it offers.
There is a list of all vmail number in forum. If I find it I will post a link to it.
Here is the link to all vmail number, credit to @Nezgar
01-06-2022 04:15 PM - edited 01-06-2022 04:15 PM
01-06-2022 04:14 PM
Yes, you can. Call your number from another phone and press * at the greeting.
01-06-2022 04:14 PM
@tomclaeys : Yes. Call your number and wait for your greeting then press * and then your password.
