05-16-2024
09:13 PM
05-17-2024
08:19 AM
computergeek541
I am a new subscriber and looking at changing subscription to the Canada / US plan. My phone is the SM-715W (4G), the specs say it has VoLTE, but when I check PM compatible devices it isnt listed. Can someone confirm that this device will work on the PM network in the US using VoLTE
Phones
05-16-2024 11:33 PM
Thankyou
05-16-2024 10:44 PM
HI @KZ1964
TextNow will give you another number, you can choose Canada or US number. Whatever number you choose, you can use it to make calls to Canada and US for free
the app will work with data or wifi
05-16-2024 10:28 PM
Silly question. With the textnow app do you have a 2nd phone # and its a US #. And uses PM data subscription? Have never used it before
05-16-2024 09:31 PM
HI @KZ1964
you would have no problem using voice in Canada
In US , it can hard to get voice. If you can connect to T-Mobile and if the area has 2G , then voice will work
But data would work very well. So, what I suggest you is to use VoIP app like TextNow to make and receive calls instead, or as a backup
05-16-2024 09:31 PM
@KZ1964 - You may be limited on the 2G network since they are in the process of taking down cell sites with 2G.
You may need to use TextNow or Fongo to receive Calls in the US.
05-16-2024 09:29 PM
Thanks What does this mean for reception when using voice in Canada and US
05-16-2024 09:17 PM
@hTideGnow - Hopefully PM disables the whitelist.
It gets annoying but these are what the "Needs" are at PM:
- Full VoLTE compatibility
- Wi-Fi Calling in Canada
And I wish TELUS still had somewhat of a 2G EDGE for those legacy devices from the 90's like the iPhone 2G.
05-16-2024 09:14 PM
HI @KZ1964
that is a A71, but it is not VoLTE compatible with PM
however, you can still use data on 4G without problem
for voice, you will have to use PM's 3G netowrk for voice
when you are in US, you will need to use T-Mobile's 2G network for voice, and again, you can use T-Mobile and AT&T 4G network for data
