08-26-2018 05:06 PM - edited 01-05-2022 12:40 AM
08-26-2018 05:18 PM
In your self service account, should be on the right upper corner on webpage.
08-26-2018 05:11 PM
Joined yesterday and how do I find my account number?
08-26-2018 05:08 PM
@Raymondi To check your PIN you set during activation, see if you got any text from PM showing your PIN. Or see if there is any text message saved on your sim card.
To change it, you will need to send a private message to the Moderator_Team with your account details.
08-26-2018 05:07 PM
@Raymondi, if you are referring to the account PIN that you selected during activation, it can only be changed by the moderators. You will need to get them to do it. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
