01-23-2020 11:21 AM - edited 01-05-2022 10:24 AM
Hello all.
I am back now, but just wondering if public mobile has a plan that I could've purchased to be able to make and accept calls while out of the country. I already have the Canada/USA Roaming.
Service
01-27-2020 11:01 PM
@kelvarnsen wrote:The weird thing was I was using 1 before the area code and number and it didn't really work (unless you mean actually having the phone dial '+' somehow).
Yes, I meant using the plus symbol - cel phones will automatically treat that as the international exit code. You dial the + by holding 0 usually.
01-27-2020 10:07 PM
@Nezgar wrote:
@kelvarnsen wrote:Also just FYI if you do purchase a Mexican SIM card it seems that you need to dial 00 before the 1-area code for it to go through. That might be obvious to others but I am in Mexico now and was surprised that when I didn't use 00 on my AT &T sim most numbers didn't go through. Surprisingly a call to my wife's PM number did to her voice mail.
If you dial +1 it should also work. Each country has their "exit code" many different , which cell phones will automatically figure it out. If you store all your contacts in this pretty way, it will work from any country, even locally in Canada:
+1 (306) 555-1212
The weird thing was I was using 1 before the area code and number and it didn't really work (unless you mean actually having the phone dial '+' somehow). The crazy thing was I called my PM phone number with the 1 in front of it and it didn't work, but when I did the same thing for my wife's PM number it did. As soon as I added the 00 mine worked fine.
01-27-2020 09:32 PM
+1 (306) 555-1212
01-27-2020 02:38 PM
I use YouMail as a replacement for PM's voicemail.
When I'm out of the country and using a foreign SIM, I can check voicemail that comes to my PM number in the app in both audio and transcribed text formats.
Even at home, it's a lot more convenient to check voicemail in the app rather than suffering through the usual VM mess.
01-27-2020 08:12 AM
01-27-2020 02:27 AM
Thanks for the great info
01-23-2020 10:00 PM
I'd prefer to purchase a new sim in Mexico when it happens to me and roaming fee is so expensive, but you can text and talk via whatapp on wifi. I used to do that in Cuba last year! I had no problem 😄
01-23-2020 11:30 AM
@Jb456 wrote:No they do not.
You could download TEXTNOW for next Mexico trip. You get a Canadian number in your area and you can call/text Canada and USA for free over wifi.. people can call,text and even leave you voicemail.
I'm in Mexico right now and use TextNow to call / text home....works flawlessly as long as you have wifi...which is just about everywhere nowadays. Most cafes, bars, restraunts and resorts have free wifi.
Alternative is to purchase a sim card available at most OXXO stores, then get a cheap talk/text/data plan.
01-23-2020 11:27 AM
Anything is possible but expansion of roaming service is unlikely. This would be above the Public Mobile pay grade; reserved for brands higher up in the Telus food chain.
01-23-2020 11:22 AM
No they do not.
01-23-2020 11:22 AM
@mellondon wrote:Hello all.
PM cannot be used in Mexico.
PM Roaming is available only for USA.
