04-16-2020 07:12 PM - edited 01-05-2022 10:24 AM
how do I confirm my new phone number on the new sim card after installing in phone
04-17-2020 02:17 AM
I had someone text or call me at the number I was given to confirm it was working.
04-16-2020 07:24 PM
hi @Valary
You were supposed to pick the number during the activation.
Did you go through the process of installation?
Thanks
04-16-2020 07:16 PM
@Valary , if your SIM card has been activated, you should be able to put the SIM card into the phone and the phone will show the phone number under SIM status.
04-16-2020 07:15 PM - edited 04-16-2020 07:18 PM
@Valary settings -system - advanced - about phone, should let you see the current phone number assigned to the phone. Alternately calling another phone would let you see the number that comes up. And logging into your self service account does the same. Welcome to PM. Stay safe.
04-16-2020 07:15 PM - edited 04-16-2020 07:17 PM
@Valary If you installed SIM in one of PM kiosks, a seller should give you a paper with all info, including your number. Otherwise, you can login your self-service profile and check the number there - click on Plan and Addons.
