06-19-2024 04:35 PM
I have been trying to call some numbers in Germany (from Canada) but I keep getting a 1B1 error, even though my forwarding settings are turned off. I tried calling these numbers on a landline (via the operator), and it worked, so it seems the issue is with my cell phone. I think the problem is to do with long distance calling, but I have two unused gifts of 500 minutes Int'l LD in my add-ons. These were gifted some years ago before the new rewards program, but they still show up in my account, so my question is if these add-ons are no longer active, or if there is just a glitch with my account and it won't let me use these minutes.
Thanks
Add-Ons
06-19-2024 05:02 PM
06-19-2024 04:58 PM
Thanks for the response. I got it working by dropping a 0 in the area code (see my other response).
06-19-2024 04:58 PM
Thank you for your response. I received a private message from a very nice user who suggested doing the 011+49, but then also dropping the 0 in the area code, and that worked! I made one phone call, and now my add-on says "1 minute used", so indeed the add-ons are still working correctly. I just would have never guessed to get rid of the 0 in an area code.
06-19-2024 04:53 PM
@EB0 wrote:I think those 500 international minutes are misleading, and for Canada and US only.
The aboe isn't correct. The long distance minutes given out during the More is Merrier campaign includes calls to: Canada, United States, China, France, Germany, Greece, Hong Kong, India, Italy, South Korea, Malaysia, Mexico, Poland, Portugal, Puerto Rico, Singapore, Spain, Thailand, United Kingdom, and Venezuela
06-19-2024 04:51 PM
06-19-2024 04:44 PM
@Sean758 wrote:I have been trying to call some numbers in Germany (from Canada) but I keep getting a 1B1 error, even though my forwarding settings are turned off. I tried calling these numbers on a landline (via the operator), and it worked, so it seems the issue is with my cell phone. I think the problem is to do with long distance calling, but I have two unused gifts of 500 minutes Int'l LD in my add-ons. These were gifted some years ago before the new rewards program, but they still show up in my account, so my question is if these add-ons are no longer active, or if there is just a glitch with my account and it won't let me use these minutes.
The More is Merrier add-ons are still active (if they haven't been used up already). Try using both 01149 and then the rest of the number and +49 and then the rest fo the number to see if that make any difference.
06-19-2024 04:44 PM
Where in Germany are you trying to call? If you can give us the routing portion of the phone number we can test call for you.
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
