Using PM in South Korea
Colin11
I’m traveling to South Korea for 15 days in October. Can I use my public Mobile Plan in Korea?
choding_guelph
when I went to south korea last year  I used the small wifi device from korea sim card. i thought it was cheapest than other company. but  I found one of company at amazon nowdays.  you should search it amazon. it is good price and easy.
hi @Colin11
local physical sim or travel esim are the only choices
Chalupa_Batman
As other have stated, sadly no. You can not. However, you can always download TextNow or Fongo while here in Canada, get a local number where you are and then call forward your PM number to that so when you have free WiFi in SK, you can use your phone still. You just have to answer through the app. People from Canada can still call you and you can still call back to Canada. Just a thought.
DDM69
Here is my recommendation for an ESIM when travelling.  You just download the app, choose your plan and make your payment.  Very easy and affordable.
https://www.airalo.com/
@Colin11   No Sorry PM has no roaming in South Korea  just the US with roaming add on .your best to get a local pre paid SIM card while your there
