08-20-2026 05:51 PM
Does my plan include ALL of Mexico? We’ll be south of Playa Del Carmen and I want to be sure.
I know sometimes companies say they have coverage in a country but it’s not the entire country.
thanks
08-20-2026 06:00 PM
you're covered in Mexico with this plan. Make sure to enable Roaming to be able to use data. You'll find best experience using AT&T, Telcel or Movistar
08-20-2026 05:57 PM - edited 08-20-2026 05:57 PM
Yes, they do
PM uses AT&T, Telcel and Movistar as roaming partners, and all 3 have coverage in Playa Del Carmen, so, you should be good if you have the Canada US Mexico plan
