Use 3G band on LTE plans?
Lonetreejim
I live in a rural Ontario community and get only 1 bar (or less) of signal when the phone is on LTE.  3 bars on 3G.  I’m on the $15 3G speed plan but I’m contemplating switching to the $35/mth 20GB plan.
I keep hoping Bell/Tellus (or Rogers for that matter) will build something closer but, as of now, no joy.
The 20GB plan is listed as an LTE plan.  Will it work (albeit at slower speed) on the 3G network?
Chrissyrioux12
Or if you want more calling do the 25 dollar plan anything more is probably pointless
hi @Lonetreejim yes you can.
the plan you sign up with is the speed, not access to the specific network.  Any Om subscribers can  freely use 3g or 4g or 5g  network they choose to
@Lonetreejim  Yes it will work but also note The 20GB for $34 you will have to pay $102 upfront with 60 GB for 90 days to work out to $34 a month
Chalupa_Batman
I'm on the 3G plan myself. In all honesty, if you're here to save money, then stick with what you have. If you want faster internet then bump up to a 4G plan. But I prefer to save money as I have WiFi everywhere. JMO.
will13am
@Lonetreejim , the 3G/4G/5G speed plans is a marketing schtick for speed caps.  All plans can connect to the 3G/4G/5G networks.  You should have no problems with plan upgrades.
