Rewards
MNPATC
I've been a customer of Public Mobile since 2019, which means it's been four years now. However, I've noticed that there is only a $2 reward for my loyalty in my account.
14 REPLIES 14
Hymmm that does sound right so  jokes on me I’ve been here since 2018 and only have $4 guess im off to support too
@Handy1- I'll use my Spring 2019 account. Start = 0. After Spring 2020 $1. After Spring 2021 $2. After Spring 2022 $3. After Spring 2023 $4.
But it’s still 2023 and that’s and that’s still only 4 years since 2019
I'm going to say it should be $4. With a couple people commenting on this today I had to review my accounts. They're all as they should be.
Here's how I think it works.
Start to one year doesn't count. So I say as I use my fingers (in this case and it turns out I have two accounts from 2019 from before today):
To 2021 - one finger down.
To 2022 - two fingers down.
To 2023 - three fingers down.
To 2024 - 4 fingers down.
Each finger means the dollar reward. And my accounts show $4 reward.
Review your payment history from here. Green numbers are good.
Adding - lol my typing problem is missing words. Usually just the little filler bridging words. I added "be" in front of the $4 on the first line.
@MNPATC  So you should see $3 for loyalty right now
MNPATC
Most Probably my anniversary day is March 2019
@MNPATC  And changing your number or plan shouldn’t have any impact on your rewards at all
MNPATC
No, I had to change my number once because of a data breach in my profile. When I got the new number, they transferred all of my rewards.
@MNPATC  If you see the $2 for auto pay that’s good Indication your still on old legacy rewards maybe get support to investigate
send a  private message   To CS_Agents click
@MNPATC wrote:
I've noticed a $2 charge for autopay and a $2 reward. I have just logged into my profile after a while and didn't make any changes, so I'm unsure if I accidentally switched anything.
@MNPATC - if you are still getting the $2 Autopay reward, then you are still on the old legacy reward program.
@MNPATC - do you often suspended your account for non-usage?
If not suspended for more than 60 days within the anniversary period, then there should be no push backs of the date of your loyalty.
MNPATC
will13am
@MNPATC , do you remember your anniversary day.  It does seem like you are in line for $3 loyalty reward even if you joined at the end of 2019.
@MNPATC  You should get $2 for auto pay and loyalty if 4 years now you should see $3 for loyalty for total off $5 did you happen to switch to the points system by accident
Add I joined in 2018 and still only get $4 note it takes 6 years to see the $5 max loyalty
Add check for your welcome email for your join date
