12-16-2024 10:03 AM
I want to use my rewards towards my bill which starts tomorrow
12-16-2024 11:00 AM
If you login and have 15 points in your rewards, you can use them towards your next bill. Should be enough time to do it today before your renewal tomorrow.
12-16-2024 10:59 AM
you have to act fast as it might not have enough time if your renewal is tomorrow
But first, do you have 15 points? you have to have 15 points to redeem for $15 credit
If you have enough points, go to Rewards sites, then go to catalogue and pick the 15 points for $15 bill credit. PM will add the credit to your account within 48 hours. That's why i said you might not have enough time if your renewal is tomorrow, but PM usually add the fund faster
