2 hours ago
Hello:
Upon insertion my simcard is not working. Does anybody know what to do next?
56m ago
@Phil102 you can pick up a replacement SIM card from Amazon for $5 and if you have Prime shipping will be free and should arrive in 1 to 2 days, or if you go to a Telus/Koodo or Mobile Klinik store you can pick one up in person for $10. Once you have a replacement SIM just go into your PM app on your device and go to the Account tab and select "Change Your SIM card".
If you prefer to reach out to a support agent to see what they might have to say you will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
an hour ago
try the sim in a diff cellphone to see if the problem is sim or cell related.
Have you tried a network reset on your cellphone...(you'll have to remember all passwords as they get removed doing this)
an hour ago
This looks like card issue. I have a card from different carrier and that is working. My phone is fine. And my public mobile account is up to date
an hour ago
Hi.
The simcard was working fine for more than a year. My app is working and my account is up to date. I went to Europe for a months. I used a different carrier simcard there. Now when I returned. The public mobile sim looks dead. The cellular line is iphone settings is greyed out. I reinserted card few times. Rebbooted phone. Nothing works. I have no bars.
2 hours ago
@Phil102 assuming you have an activated account, can you try the SIM in another phone to see if the issue is your device or the SIM?
2 hours ago - last edited 2 hours ago
more info please...did you download the Public Mobile app and successfully activate a PM account ? Did you initiate a port of your old number in to your new PM account ? If so, did you reply YES within 90 minutes to the confimation ?
clipped from Help Files...
https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
