05-18-2024 10:33 AM
Hi
I check my usage today and I noticed bunch of outgoing calls and sms that I didn't do. Is there a way to verify those messages are from my phone?
05-18-2024 11:28 AM
If you see outgoing calls ending with 4001/2 that is calls going to your voice mail.
05-18-2024 11:23 AM
@BreezyHedgehog wrote:Hi
You would be soooo much better off if you just asked CS for clarification. All you'll get on this forum is nice people guessing as to what seems reasonable. Save your self from getting well meaning wrong directions and just contact the people that a hired to help us.
05-18-2024 10:35 AM
for calls, if they are going to number ends with 4001, those are voicemail calls. They are recorded there if you ever call your Voicemail from your phone or if people called you and got routed to VM because you cannot be reached at that time
for sms, did it show as outgoing text? what number it is going to? Some apps or OS would send sms automatically to servers for setup/validation purposes
