11-12-2024 03:04 PM
How do I find out how much data I have used historically as is month to month over time?
11-12-2024 03:21 PM - edited 11-12-2024 03:22 PM
You can filter out data, calls and SMS texting. On the PM app or online, Under Subscription tab>Usage Breakdown>View Usage History then filter 7, 15, 30, 60 & 90 days then click on Apply Filter.
11-12-2024 03:06 PM
@jocefrenette Remember PM is 30 days and 90 days cycles not monthly , but you can view your usage history in your accounts over view page near bottom of the page . And also note the usage history is only updated 2x a day so you’re always seeing the last 12hours used . If you have android you can keep track of data used in phone settings also
11-12-2024 03:06 PM - edited 11-12-2024 03:06 PM
hi @jocefrenette usage history in My Account go back 90 days
Try to download it in Excel formal and use Excel to sum it up
and sorry, no further than 90 days
