05-17-2024
04:33 PM
05-17-2024
06:08 PM
computergeek541
Is it possible to transfer a Telus ph number to an existing PM sim card that is already activated?
I want to change my current PM phone number to a Telus number that my friend has and is about to close her account with Telus.
If that's not possible, is it possible to transfer the Telus number to a new PM account that i will get activated?
05-18-2024 11:33 AM
HI @El_Gato
you can transfer any Telus number to an existing PM account. But it is like a port, once the number is transferred, the Telus account would be closed.
so, yes, transfer from Telus is pretty much same as ported from Bell to us
05-18-2024 11:29 AM - edited 09-26-2024 11:57 AM
So is it possible to transfer a Telus number to an existing PM account ?
05-17-2024 06:11 PM - edited 05-17-2024 06:12 PM
@Chalupa_Batman wrote:I want to change my current PM phone number to a Telus number that my friend has and is about to close her account with Telus.
This could be tricky. As the number is hers, it should be in your name. However, if you try porting over the number, make sure when the text comes to her phone, she says YES and hope there are no problems transferring it over. If there are, you will need her with you when you contact support.
There are no additional complications when it comes to the Telus account being under someone else's name. The porting process remains the same. Permission from the friend is needed, but its' as simple as typing the friend's name on the number porting form. That name does not need to be the same as the name on the Public Mobile account.
05-17-2024 04:46 PM - edited 05-17-2024 04:48 PM
Hello @Vincerice
@Vincerice wrote:Is it possible to transfer a Telus ph number to an existing PM sim card that is already activated?
The answer, YES. You can port over any number from any provider to your current SIM card/Account.
I want to change my current PM phone number to a Telus number that my friend has and is about to close her account with Telus.This could be tricky. As the number is hers, it should be in your name. However, if you try porting over the number, make sure when the text comes to her phone, she says YES and hope there are no problems transferring it over. If there are, you will need her with you when you contact support.
If that's not possible, is it possible to transfer the Telus number to a new PM account that i will get activated?Answer, Yes. She can always port over her number to a new Public Mobile account.
