Usa talk and text 15 days
Parke03
Texting under this add on package is not working for me. I don’t know why? They keep failing?
@Phil_Adelphus
you could be right that MMS might not work in US.  I think I saw a post before saying MMS  in US will use your mobile data quota, so MMS might not work when you roam with only a Text/Talk roaming addon
Phil_Adelphus
@Parke03  What app are you using for texting?  Only SMS texting is included under talk & text, so if you are trying to use something like iMessage or FB Messenger then you would need data as well as talk & text.  One thing I'm not sure about @softech is MMS for US roaming with a talk & text add on only.  I know MMS doesn't come out of the data allowance even though it uses data, but would it still work on a US talk & text add on without data?  I presume that data roaming would need to be on regardless.
HI @Parke03
texting should work easily without much problem.
which networking you are connecting to? Try manually connect to T-Mobile and AT&T.
Since you might need talk, start testing with T-Mobile, but try AT&T also if T-Mobile does not work
