02-26-2023 03:12 PM - edited 02-26-2023 03:22 PM
I have tried three times today to purchase the $30 talk text data plan to no avail… why?
Add-Ons
02-26-2023 03:43 PM
For as long as I know there has always been the weird waiting period. Since the funds are in your balance, you could wait for the 0/15 items to disappear and then use the funds to re-buy the add-on. Or use support.
02-26-2023 03:32 PM - edited 02-26-2023 03:33 PM
Not to re-buy the SAME U.S. roaming add-on.
There's always been the 24 hour wait involved - yes, it's stupid. One of the many things around here they gotta fix.
Get customer support to add it for you, then it'll be available.
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
02-26-2023 03:30 PM
@Pearwasp It’s a strange glitch with the US add on … but if you reach out to support and submit a ticket you can shave them add it for you manually … or pick another US add on unfortunately
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
02-26-2023 03:28 PM
Yes I was charged by PM and I have a balance there. In the past I have only had to wait minutes not hours
02-26-2023 03:28 PM
Yes. I removed the number
02-26-2023 03:26 PM
hi @Pearwasp remove your phone number, we are just customers
you checked CC and PM didn't charge you?
you might need to wait an hours to try buying again. You have tried 3 times and might have a fraud lock there, you need to wait the hour to try again.
Try again by logging in My Account with Incognito/private/secret mode when you are ready
If still cannot buy, open ticket with PM CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-26-2023 03:26 PM
@Pearwasp It’s a known issue here in the community that trying to re buy same US add on after 15 days of first ending you have to wait 12-24 hours otherwise you need to purchase a different US add on , only support can apply it for you right away back to back …. If your credit card has been charged check you self serve for available funds should be there …. But you need support if this is a re buy of same US add on without waiting
02-26-2023 03:23 PM
- Yes I did this but nothing
02-26-2023 03:22 PM
Never had to wait before every
02-26-2023 03:16 PM
@Pearwasp Also if you’re trying to re buy the same US add on back to back you have to wait 12 -24 hours after the first one ended unless you buy a different US roam add on … if you want the same one back to back you need help of support also
02-26-2023 03:14 PM - edited 02-26-2023 03:18 PM
@Pearwasp Please edit your post and remove phone number check if you have actually purchased them here
Check add-ons /mins /Data
if you need support to for a refund here the link
