My account
Dino1968
iam having trouble signing into my account to change my cell plan as I can’t remember my 4 digit pin I used when I first joined public mobile 2years ago I need Help
2 REPLIES 2
hi @Dino1968 did you try using the Reset password button there?
or open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
@Dino1968  Try again incognito private mode or another device or lap too .. if all else fails get support to help you re gain access
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
