11-22-2024 04:25 PM
How do i change my public mobile phone Galaxy S5 to a Galaxy S22, as they have different sized SIM cards?
11-22-2024 04:35 PM
Thank you. I will save this information. 😊
11-22-2024 04:27 PM
hi @Misty611 if you look carefully, you can remove the outside and make it smaller to fit the new phone
but just in case you want to get a new sim card,
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
11-22-2024 04:27 PM
@Misty611 Just pop the outer edge off the SIM card to fit sim tray of new phone
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
