11-29-2023 01:50 PM
I was going to upgrade my plan but I had a promotion attached to my account for $20 off for 15 months with still time remaining on it. Wondering if I were to change my plan to a plan that is the same price just more data would that $20 off still continue until it expires in march. Thank you.
11-29-2023 02:25 PM
I do not think you will get the same promo even if plan cost the same (with more data).
Promos are tied up with very Specific plan so changing it you forfeit any perks associate with it.
11-29-2023 01:58 PM
Promos are usually plan specific, I would double check the fine print that's in your current contract/plan.
If you will loose it, then you have to determine if the new plan you want to switch to is worth giving what you are currently getting.
11-29-2023 01:54 PM
Promos are usually attached to the plan you are currently on. I would confirm with an agent.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
