07-25-2022 01:25 PM
My plan goes from June 28-July 28. Trying to upgrade from $25 to $35 but will only allow me to select the $15 plan. Anyone assist?
07-25-2022 02:08 PM
private browser WORKED THANKS!!!!!!!!!!!!!!!!!!!
07-25-2022 02:07 PM
LOL Yes Thanks, another user suggested private browser and it worked
07-25-2022 02:05 PM
@K1968 Are you seeing the arrows?
07-25-2022 01:51 PM
Just tried and it works as expected. Clicking on right arrow it scrolls down and highlights next plan.
Try Edge, Firefox. It works even with my ancient Firefox so cannot be any issues with the site.
07-25-2022 01:45 PM
@K1968 That is odd situation then, but like I said clear your cache/cookies and wait an hour before retrying. PM has all sorts of glitches in the system which seem to have multiplied since the new account rollout.
07-25-2022 01:42 PM
@K1968 you definitely in the right place.
No luck with Chrome Incognito mode? and you tried Edge and Edge InPrivate mode?
07-25-2022 01:41 PM
Exactly, no.....greyed out. Does nothing when clicked, only the $15 plan option in white
07-25-2022 01:39 PM - edited 07-25-2022 01:39 PM
@K1968 So when you click the down arrow (over on the right hand side of plans), the next plan doesn't populate on your screen?
07-25-2022 01:37 PM
07-25-2022 01:37 PM
@K1968 Clear your browser cache/cookies before trying again. I'd wait an hour too as PM's website is known to have glitches every now and again.
07-25-2022 01:34 PM
try using Chrome in Incognito mode ... or Edge
did you use the up and down arrow to scroll up and down ? When you are there in the plan, it should show the 2 buttons "Change Now " and "Change on the next renewal date"
do you mind to provide us a screenshot?
07-25-2022 01:30 PM
I am using Chrome on laptop
07-25-2022 01:29 PM
I tried that, all greyed out except the $15 plan
07-25-2022 01:27 PM
@K1968 Use the arrow on the right side of the plans to scroll down or up to view other plans.
07-25-2022 01:26 PM
