07-25-2022 02:00 PM
My son has a phone with Public Mobile which is billed to my account and has been stolen. It won’t let us log in to his account to cancel It
07-25-2022 02:07 PM
@Trenag You'll need to submit a ticket to customer support and ask for a password reset/assistance with putting the account into suspension. Here's a link to chatbot: https://www.publicmobile.ca/en/on/get-help
BTW, make sure you have cleared the cache/cookies and are using privacy/incognito mode and there's no typos when logging into your account.
07-25-2022 02:06 PM
@Trenag you just want to suspend the line until you got a new sim card and phone and reactivate?
If so, try to get back the access to self serve My Account, then disable Pre-authorized payments
To get the access to SelfServe My Account back, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
