Upgraded subscription
Jab2
I upgraded my subscription almost 2 months ago from 3G network to 4G.  I am still just getting the 3G, which means today I did not receive the national alert test.  I tried shutting phone off and turning back on but nothing changes.  I have the IPhone XR and the most recent updates.
Can you offer other solutions.
8 REPLIES 8
Jab2
3G or LTE are the only options that are shown.
@hTideGnow wrote:
HI @Meow
you are on 3G plan, but 3G plan is just about speed.  Anyone on the 3G plan can still use the 4G and 5G network but just the speed capped at 3Mbps
your phone is connected to 4G network and hence you got the alert (if you set your phone to Automatic, your phone will choose either 4G or even 5G network)
Much appreciated your explanation!
Thanks!
Personally do not care about data speed as I do not use internet on phone. Occasionally if I am out of range of free WiFi... As long as phone/sms works do not care if it is 3,4,5,6,7G 😁
HI @Meow
Meow
I am still on '3G plan' but I did get national alert. Why would alert be restricted to >=4G???
DennyCrane
You changed to a 4G plan, not the ability to connect to the 4G network (you already had that ability). Even on your 3G plan you can connect to the 4G network (you could have connected to the 5G network as well, but your phone isn't 5G compatible. Your plan just dictates the max speed you can achieve.
@Jab2  changing plans won’t change the setting in your phone you need to go to phone settings and change it to 4G/LTE or 5G and you will bet the text alerts
HI @Jab2
yes, you won't get the alert if you are connected on the 3G network.  But check if your phone was set to connect to 3G instead of Automatic
To set your iPhone to 4G, you can do the following:
Go to Settings -> Cellular -> Cellular Data Options -> Voice & Data
Select 4G
