Upgrade
12-27-2024
06:41 PM
12-27-2024
11:21 PM
computergeek541
12-29-2024 12:07 AM
Hi thank you . I got it now. 😊
12-28-2024 11:37 PM
You should have lots of options then. Login to your account and go to Manage Subscription. Make sure to make the change effective your renewal date, not now.
12-28-2024 11:36 PM
Just wondering to upgrade to their specials for new customers
12-28-2024 11:35 PM
Its 25.00 a month
12-27-2024 08:37 PM
What plan are you currently on? If it's more than $35, you likely won't see this option. A workaround is to renew into the $30 plan now, which will unlock the $35 plan that you can then schedule a change to it at next renewal. Just know that you won't get any credit/refund for unused time in your current cycle if you renew now into the $30 plan, but if you wait that deal will likely be gone on January 1st.
12-27-2024 06:42 PM
difficult to downgrade plan once you have a plan of higher cost. Which plan do you have and which plan do you want ?
